thanks for the link, unfortunately it did not show pin designations. I was just trying to drive the thing to see what I could do with it. I guess I don't know what I want to do with it. I think it is in the unvisible red spectrum. I may want to modulate to use with sensors or just turn it on to make it light something somehow.
Here's a spec sheet for the LT022MC.
http://www.alldatasheet.com/datasheet-pdf/pdf/SHARP/LT022MC.html
Sam's Laser FAQ has quite a few laser diode drivers.
http://repairfaq.ece.drexel.edu/sam/lasersam.htm.
You could probably interface the Stamp with one of the drivers.
Are you trying to modulate the diode or simply turn it on or off?
Dave G
Mike W
