waitkey function for bs2? — Parallax Forums
dr_eggman198dr_eggman198 Posts: 15
edited 2005-07-05 23:59 in BASIC Stamp
I was wondering if there is some type of pbasic command that woulld be similar to a waitkey function, where the basic stamp wpuld have to wait until a signal was sent to a pin in order to proceed with the next line of code.
  • Philip GamblinPhilip Gamblin Posts: 202
    edited 2005-07-05 23:43
    look at PULSIN and/or DEBUGIN in the help files.
  • NewzedNewzed Posts: 2,503
    edited 2005-07-05 23:44
    Take a look at the "ON" instruction in the Editor Help file - will that do what you want?
    Sid Weaver
    Do you have a Stamp Tester yet?
  • dr_eggman198dr_eggman198 Posts: 15
    edited 2005-07-05 23:54
    i'm making a tic tac toe circuit, and the stamp outputs at a certain pin that corresponds to a led based on what the human has input. for example, if pin 7 and pin 9 are on, and the human inputs 8, then the stamp will output pin 5. But if the human doesn't input at pin 8, then the stamp will output at a different pin. The problem is that I think the stamp will assume that the human didn't input at pin 8, because of the bs2's speed over the human's,
    You could use a DO...LOOP, for example:
    DO : LOOP UNTIL IN0 = 0
    This piece of code will sit in that loop until the active LOW (Pulled HIGH) button on P0 is pressed.
    csavage@parallax.com
    edited 2005-07-05 23:56
    Okay, your new post kind of negates the previous one I posted.· That's a whole different concept.
    ok, that seems like it will work. Thanks.
