bs2p40 drops out when one of the Main I/O outputs is tured off
I have a bs2p40 main output going thru a ULN2803A which goes to a Potter Brumfield 5Vdc, 15mA relay.· The other side of the relay coil is tied to 5Vdc.· The ULN2803A is tied to 5Vdc and ground.· All of the listed devices share a common 5Vdc supplied by a LM7805C with a 10 uF capacitor·tied to the 12 Vdc input and a 1 uF capacitor tied to the 5 Vdc output.
When I turn on three of the outputs and then a few seconds later turn one of the outputs off, the 2p40 crashes.· I have tried running separate grounds for each of the devices back to the main supply terminal, I have monitored the 5Vdc supply when the 2p40 crashes and can not whitness any voltage noise caused by the relay dropping out.· I am only able to monitor for this at 240 samples/second so I may not be able to catch the noise event, I do not know.
Any ideas?
thanks,
James
Any ideas?
thanks,
James
has suppression diodes built in....but the device might not be doing it's job properly.
Ken
Jon Williams
