I have a multimeter Metex M3850D. Wen i try to make a mesurement i have a problem. Now i don't see nothing on the display. Can you help me to resolve this problem. My name is Marcos Silva from Cape Vert
When I got my first MM I made the mistake of trying to measure the current of a circuit by placing it in parallel with the ciurcuit instead of serial. This low impedance path made much more current flow through the MM than it was designed for, and a fuse inside the MM was blown, openning up the MM and replacing the fuse fixed the problem.
LOL, I sent my $250 dollar MM to hell the same way. I took it one step further though. Swapped the low range(1A) and high range(10A) fuses because I was in a pinch, forgot about it, made the same mistake a week later.....Poof! Everything still worked except the current portion! Now I keep a box of fuses in the case of my new meter.
Also check you leads/probes.· is the wire firmly connected to the jack and to the probe?
