SX52 info — Parallax Forums
SX52 info
RsadeikaRsadeika Posts: 3,864
edited 2005-07-04 00:13 in General Discussion
Two questions:
1.A description for Port A states "symmetrical drive". Can someone, in lay terms, explain what that refers to, and how it is used.
2.Is their a way of adding or accessing more data memory. This would be within the context of the SX proto board. The docs state 262x8, I guess to some, salvation would be in order. But since their is a 5 bit addressing scheme, have I answered my own question.
PS please save the sarcasm for someone else.
  • pjvpjv Posts: 1,903
    edited 2005-07-03 22:56
    Hi There;
    Symmetrical drive means the transistors in the port can "push" (source current) equally well as they can "pull" (sink current).
    As far as data memory is concerned; not directly, but certainly via software, either parallel (uses lots of I/O pins) or serial (uses many fewer I/O pins).
    Cheers,
    Peter (pjv)
  • RsadeikaRsadeika Posts: 3,864
    edited 2005-07-03 23:34
    Peter, thanks for answering the questions without a brow beating. Could you answer two more?
    1.Hi-Z input or output, is this like turbo mode(lol)?
    2.TTL and CMOS, ·which would be preference.
    Thanks.
    edited 2005-07-03 23:39
    1. Hi-Z (high impedance) in when the pin is set to an input state; when made an output there is a low-impedance path to Vdd (high) or Vss (low).
    2. That depends on where you want the transition to occur. When timing the discharge of a cap, for example, TTL is preferable as the transition is at 1.4 volts so there is a greater "distance" between 5 (fully charged) and 1.4 (transition to 0). If the pin was set to CMOS and running at 5 volts, the transition point would be 2.5 volts. Given the same cap timing routine, the granularity would be greater.
    Jon Williams
    edited 2005-07-03 23:44
    Well no, they are totally different issues.
    Turbo refers to the mode the SX is operating in; that is downward compatible with some (1655??) PIC's reduced feature set. Hi-Z refers to an output's being temporarily disconnected so it neither sinks or sources. Inputs are always (relatively) Hi-Z.
    TTL/CMOS depends somewat on your application. In the many years I have been programming the SX, I have never yet used TTL. I like the concept of the processor switching at half of Vcc. It allows me to play a lot of analog tricks with the SX.
    Cheers,
    Peter (pjv)
  • Guenther DaubachGuenther Daubach Posts: 1,321
    TURBO Mode ???
    When I bought a PC software product many years ago, it came together with a bumper sticker reading "I feel the need for speed" - fortunately not too many German cops understand English smile.gif .
    Using an SX comes close to driving a racing car, so why should you throttle it down?
    Therefore, each of your assembly programs (for SXes below 48) should contain those two directives:
    DEVICE TURBO
    DEVICE OPTIONX
    to make use of their full power (not necessary for the "larger" 48/52 devices - they are racing cars by default).
    Happy SX-ing,
    Greetings from Germany,
    G
