Debounce Question
Should PAUSE be used to debounce a button? I know BUTTON can be used but I've read something about losing time. I would like to keep away from Schmitt trigger input for it takes board space.
Below is a barebones version of the application that I'm developing:
SelBtn PIN 13 Pressed CON 0 Main: DO DEBUG CLS, "Task 1" DO:LOOP until (SelBtn = Pressed) PAUSE 250 DEBUG CLS, "Task 2" DO:LOOP until (SelBtn = Pressed) PAUSE 250 DEBUG CLS, "Task 3" DO:LOOP until (SelBtn = Pressed) PAUSE 250 LOOP END
btn··· VAR··· Bit
idx····VAR··· Nib
Scan_Button:
· btn = 1····················· ' assume pressed
· FOR idx = 1 TO 10
··· #IF ActiveLow #THEN
····· btn = btn & ~BtnInput··· ' invert active-low input
··· #ELSE
····· btn = btn & BtnInput
··· #ENDIF
··· PAUSE 5
· NEXT
· RETURN
The way this works the button must be pressed on entry and remain pressed without "bounce" through the routine -- a little longer than 50 ms.
I've tossed in a bit of advanced trickery ... the symbol called ActiveLow is a conditional compliation constant; if it is not defined (or defined as 0) then the program will assume active-high input(s).· Yes, the routine uses PAUSE, but is loops through a group of short-duration pauses, checking for contact bounce in between.
Jon Williams
Thanks for your feedback. You are absolutely right about having a long duration of pause can be a disadvantage. In my current application, a POLLIN and POLLRUN are being used and if the application is in PAUSE, and the POLLIN pin is pulled low momentarily before PAUSE has finish executing, POLLRUN would never execute.
One thing I still don't understand in your above code is why you inverse the variable btn every 5ms or so?
For the original code I posted above, should a debounce subroutine suffice? The code would look something like this:
Thanks!
Jon Williams
