Boe- bot wont open
I just changed the batteries for·my boe bot and it wont open again?
I checked the polalarity and it is right but still wont open. I try downloading
a program and there is no Basic Stamp found. the BS2 is also in the socket suggly.
·HELP!!!!
·HELP!!!!
·· It does sound like weak batteries.
csavage@parallax.com
how can I check?
·· If you have a continuity checker or ohm-meter you could check for continuity between the battery back and the end of the cable.· There are only 2 points inside the battery case that connect to that adapter.· The one connected to the positive end of the battery should connect to the center of the barrel connector, and the other to the outside.· If you do not get any continuity then there could be a break in a wire somewhere.
·· Please contact Tech Support at 1-888-997-8267.
