h bridge motor controls
I plan to have my class go beyond boe bots this next year and design a robot with (2) 12 volt, 1-amp @ stall, gear head motors.
Any suggestions for a·suitable h-bridge·circuit to connect to a Basic Stamp 2 ?
We also want to control some other circuits via a 12 volt relay.· Does anyone have a working mosfet circuit we could employ?
· I'm doing this with discrete components so the students can build the electronics.
Thank you.
jcurrie
Thank you.
jcurrie
We used a BASIC Stamp and FETs for partial control of DawgZooka - A T-shirt shooting Bot on a Bomb-Disposal ROV Chassis. While IFI controllers were used for the main drive, descreet components were used for a high current H-Bridge, and indivual FETs for light controls and solenoid firing.
Here's some of the main parts (DigiKey part #'s):
LT1161CN-ND - MOSFET Driver
IRL2203N-ND MOSFETs for use with driver (note, you need a diode from gate to ground on lower H-bridge to limit voltage)
RFP30N06LE-ND - MOSFET for on/off control of devices.
We also had a printed circuit board designed with the BASIC Stamp, the divers, and Input/Output for RC radio and servos so the Stamp can take orders from the RC Conroller.
I don't have the schematic on in electronic format right now, but I can scan it next week and send it if it would help.
-Martin
Martin Hebel
Electronic Systems Technologies
Southern Illinois University Carbondale
Personal Links - ·Lot of BASIC Stamp info
and
SelmaWare Solutions
StampPlot Pro Version 3 Release 4
Graphical Data Acquisition for your Micro and Imagination!
Now allows additional controls to be added, or developed.
http://www.mcmanis.com/chuck/robotics/tutorial/h-bridge/index.html
A jug of wine
A loaf of bread
And thou
I'm·just curious without looking at the datasheet is an irll3303 a similar but beefier version of the irll2203.
I have come across it in a fisher and paykel washer motor controller and always blows it's guts out when the pump is faulty or when the user opens the lid at full spin speed.
Reasons established so far the pump is used for 3 purposes in this machine.
1.pump water out
2. part of low voltage supply for the display controller (user interface with buttons and leds)
3. Power from magnetic braking is dumped through it. so if the impellor is jammed lookout.
Sorry I know this is off topic I have yet to study your documentation on Dawgzooka but it is on my computer for when I get the chance. Interesting bot.
It looks like the irl2203 is a lot beefier - 116A compared to around 30A for the 3303. Go figure [noparse]:)[/noparse]
So, I wouldn't use it as a replacement!
-Martin
Martin Hebel
Southern Illinois University Carbondale -Electronic Systems Technologies
and
SelmaWare Solutions - StampPlot - Graphical Data Acquisition and Control
Personal Links with plenty of BASIC Stamp info
