Servo Cable Length
Greetings-
Just got as PSC for my BS2. The servos that came with the kit have a ~foot cable to connect them to the PSC. Can I extend the cable length to ~12 feet without damaging the PSC or servo? If that’s not possible (and I suspect that is the case), could you suggest any driver circuits?
BTW, great forum. Very insightful dialog.
TIA,
Claude
Post Edited By Moderator (Chris Savage (Parallax)) : 6/29/2005 4:05:21 AM GMT
TIA,
Claude
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
But, I have never seen a 12 foot cord. The main problem is the pulse width modulated signal as you can move to larger wire for the power supply, but PWM requires you maintain some quality as well.
You could try a coaxial cable to keep the signal from becoming noisy and could add a transistor or an op amp (depending on how much gain you want) to boost its power. I suspect a 2n2222 would provide enough gain if properly included.
To review, you have main two issues.
1. providing a powerful enough signal
2. avoiding collecting noise from the length of the cable.
and one minor issue
3. the voltage drop in the small wire size on the power supply
G. Herzog in Taiwan
Post Edited (Kramer) : 6/29/2005 3:54:07 PM GMT
Now, a MAX232 driver on one side, and a MAX232 on the reciever side, should allow a nice sharp signal to the servo. In this case, you'd be using the drivers merely as a TTL to +- 10 volt converter, and take advantage of the larger signal to go longer distances with less distortion. That should be good to 150 feet or so.
Either way, experimentation will tell you what will work. I would use a shielded cable in either case, as you want to minimize noise on this line.
Couldn't you just drive the signal through an IC driver chip rather than a Max232?· If would be a much cheaper chip.· Some invert the signal, but I think you could invert it twice to get the output to be the original.· I am thinking of a 74HC240.
Wouldn't twist pairs enhance the clarity?· You could use four wire phone line and double the ground if that doesn't drop the power.· Also, it would enable you to use the telephone plugs for modularity.
G. Herzog in Taiwan
Post Edited (Kramer) : 6/30/2005 11:35:09 AM GMT
Twisted pairs in 485 helps keep the common mode noise common to both conductors.
Now, RS232 is a 'single-ended' signal -- one signal wire goes positive and negative, compared to a ground wire. This does NOT eliminate common mode noise, thus the helpfulness of a shield.
Don Buczynski
http://www.buczynski.com
Post Edited (Don Buczynski) : 6/30/2005 11:40:18 PM GMT
