Bigger batteries
Would it be possible to use 4 C-size batteries instead of AAs? I know I would have to install new holders.
bugg
Boe-bot: $229
Toddler: $249
Learning Google is your friend: priceless
bugg
Boe-bot: $229
Toddler: $249
I've actually been looking at using two lithium polymer (LiPo) 3.4vdc cells -- LiPo has the best power-to-weight ratio of any commercially available battery technology right now, and a decent-sized LiPo pack for a BoE-Bot or Toddler only runs you about $10, and is rechargable hundreds of times (obviously a charger is an additional cost).
-marc
bugg
Boe-bot: $229
Toddler: $249
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
(Not all stores have them. You may have to search them out online)
And if that isn't enough, I spotted some 8000mAh D-size Ni-mh's in a shop today...
Don't visit my new website...
Check the link above they have a wide selection of high capacity rechargeables available.
Remember that if you're using rechargeable AAs of *any* sort, you'll need five instead of four of them because they have a lower nominal voltage, and the BoE-Bot's regulator needs some headroom.
(Trust me: I have some of the NiMhs in question
-marc
Thanks for all the help!
bugg
Boe-bot: $229
Toddler: $249
