Cmucam2
Hello - new here.
Has anyone successfully used a CMUCAM2 with a BS2?·
Is the BS2 powerfull enough to analyze the matrix captured video out data?
The CMUCAM2 seems to be configured for a PC.
Chris
Chris
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
[noparse][[/noparse]url]Http://www.parallax.com[noparse][[/noparse]/url]
Yes. The CMUcam1 and CMUcam2 hardware interface is identical.
>>>Is the BS2 powerful enough to analyze the matrix captured video out data?
No. But you can do most of the processing directly on the CMUcam2 by knowing what commands to call and in what sequence.
>>>I would like to do some simple Matrix analysis (watch movement of a reflected laser line to do simple triangle trig to calculate the width/distance of an object)
You can use the CMUcam as a laser rangefinder if you use a visible spectrum laser (usually red). You don’t need to do any math. Knowing the lens field of view is usually enough ie – where the laser falls in the image equates to the range.
Update: D'oh!· I'm always getting that wrong.· Thanks.
Post Edited (allanlane5) : 10/24/2005 8:29:09 PM GMT
·· Actually it's 26 bytes (13 Words).·
csavage@parallax.com
I am planning on using the CMUCAM2 histogram to do an analysis of "jumps" in a projected laser Horz. line in the camera's field of view.
The height of a jump in the Bin will give the distance of the object - while the number of hits in the bin gives you the "width."
The centroid feature (of only the jumped portion) will give the location of the detected object- and if it is in the path of the BOEBOT. From this we can steer - maybe some use for the "edge" analysis- but I'm not there yet.
Laser Line modules on EBAY are available for less than about $12.
(any thoughts?)
Chris
