LCD question
is it posible to connect a parallel LCD to a basic stamp?
1 + 1 = Window
0............................................0
0.(Microman171@hotmail.com)..0
1 + 1 = Window
Jon Williams
i just did this about 1 hour ago so i have lots of little hints, well actuialy i have 2, use the schematic found on P. 238 in the BASIC Stamp manual or P. 242 in this document whic can be found here (which is the BS manual in a .pdf) and with Mr. Wiliams permision i will post the code he gave me for a BS2 or you can use the attached code for a BS2P!
have fun,
-mm
1 + 1 = Window
Jon Williams
if you use that code with the schematic in the PB manual be sure to change E to pin 0 under the pin definitions
1 + 1 = Window
