Simple question about ceramic oscillators
I got the oscillator to function correctly on the bread board, but when I soldered it onto a regular board it doesn't work. Is it possible that got the oscillator to hot during soldering? I don't think I kept it hot to long, but I did use a normal size iron, not one of the smaller ones.
-John Whitfield
-John Whitfield
cbmeeks
in the meantime, I have hand-soldered hundreds of these Murata ceramic resonators without killing one. I found one defective on a couple of hundred boards that I give away for machine-soldering. So, just one defective resonator out of about 800 is not a bad ratio. But you never know, maybe, you got the one with the 1/800 probability right at the beginning of your SX career
Another idea is to use a small 3-pole socket for the resonator, like on the SXTech board. With this socket installed, you can remove the resonator when you want to do on-board debugging without the need for a jumper to open the OSC1 line to the resonator when the SX-Key is in action. For just programming the SX you don't need to pull out the resonator - just for debugging.
Greetings from Germany,
G
On your regular board, do you have a resistor across the resonator(OSC1 to OSC2)? Like a 10K or 1 meg.
Sometimes the resonator has difficulty starting without this resistor. See Appendix E, Table 35 of the SX Key
Development System Manual for the correct value.
Dave G
I think your resonator is too far away from the SX.
Move it closer.....
William
Since John didn't post a picture of his PCB layout, what makes you think the resonator is "too far away"?
Thanks, PeterM
JT
Post Edited (Miner_with_a_PIC) : 6/30/2005 11:41:13 PM GMT
I always follow the specs shown in the Ubicom SX datasheets. With a 50 MHz Murata ceramic resonator, I parallel 10 kOhms (as specified), and never had problems with this configuration. The lengths of the OSC1/2 leads between the SX pins, the resonator, and the resistor, usually are less than some millimeters here.
G
JT
-John
