RFID - More than an ID reader?
I just finished reading the articles re: the new RFID reader. It strikes me that, since the data decoding is all done in software (i.e. under user control), that the reader can decode whatever ASCII string is sent - be it serial data, ID data, or whatever. In particular, if the passive transmitter were a datalogger, let us say, the reader could interogate the logger complete with ID and data. Has anybody heard of a passive RF logger available in the marketplace?.......Pete
·· I'm not sure if that would work or not on our RFID reader.· Or many others for that matter.· The thing is, the device is usually designed to read in one valid tag at a time.· To get a continuous stream of data from a device would probably involve a tedious process of both devices maintaining a somewhat crude handshaking as each byte is requested by the reading signalling the data logger via it's RF transmit sequence, and the logger sending one block of data back via RF, then waiting for the next transmission from the reader.· I hope that was a clear explanation.· This isn't to say it can't be done.
csavage@parallax.com
Sid Weaver
Do you have a Stamp Tester yet?
Sid Weaver
