Following a line
What is the preferred component to follow a line: a photoresistor or a photodiode (LED)?
Thanks,,
hvn1
Thanks,,
hvn1
To answer your question, I prefer IR because ambient light is less of an problem
This is simply my twisted experience. The good news is that the test track was fairly simple to ·construct with electrical tape on white poster board.
good luck
Here are the Parallax offerings for line following which I'm told work really quite well, although I've never actaully used them. I mention them in case you don't want to build them from the ground up, and would like to purchase something that's "Parallax-Reliable / Parallax-Supported" and well tested. Sample code is also provided. Two formats are available.
Single QTI Sensor line follower mini-board (neat duaghter-board package!):
http://www.parallax.com/detail.asp?product_id=555-27401
Full line follower parts kit for the Parallax BOE-Bot, but could be easily adapted for other bots: http://www.parallax.com/detail.asp?product_id=28108
Bruce Bates
I have the standard BoeBot kit. With it are IR LED's...so I suppose I can use those for line following, right?
hvn1
