Creating aliases to array sections
I am running out of variable space for my program. I am trying to
come up with a scheme for re-using· some variables but give
them descriptive names for each section of code.
This is what I am trying to do:
[noparse][[/noparse]code]
temp······ var· byte(4)··· 'create a 4 byte array
···· 'comments on what alias is used
···· 'temp(0)···· alias: addr,msg_addr(LN),msg_length(HN)
···· 'temp(1)···· alias:iobyte,msg_number(LN)
···· 'temp(2)···· alias:led_num
···· 'temp(3)···· alias: something
'now I am trying to create aliases to various parts of the array
addr······· var··· temp(0)
····· ' ****·· get complier error "expected '.' or end-of-line" ·********
'tried this
addr······ ··· var······ temp.byte0··· 'no error on this
iobyte······ · var······ temp.byte1···· 'no error on this
LED_num· var····· ·temp.byte2··· 'get error: "expected a variable modifier" on the· BYTE2
I am trying to use this method so that in parts of the program, I can do
something like this and reuse variables;
· for index = 0 to 3
····· temp(index) = hr_min.nib(index) + $30
· next
[noparse][[/noparse]/code]
Is there any· way of doing this?
This from the HELP manual;
It's fair game for aliases and modifiers, both in VAR directives and in instructions.
Thanks for any help,
Bob
PS: I am using version 2.2 of the editor and pbasic 2.5
Post Edited (southernbob) : 6/24/2005 9:13:55 PM GMT
'tried this
· next
Bob
temp···· VAR··· Byte······· ' same as temp(0)
temp1··· VAR··· Byte······· ' same as temp(1)
temp2··· VAR··· Byte······· ' same as temp(2)
temp3··· VAR··· Byte······· ' same as temp(3)
With the "array" declared manually as above you can alias its elements.· The only caveat is that you must define and keep your elements in order.
As an example of where this implicit array can be useful, this subroutine will stuff the entire contents of RAM into the Scratchpad (for those Stamps that have it):
Push_RAM:
· PUT 0, B0
· FOR B0 = 1 TO 25
··· PUT B0, B0(B0)
· NEXT
· RETURN
To "pop" the RAM:
Pop_RAM:
· FOR B0 = 1 TO 25
··· GET B0, B0(B0)
· NEXT
· GET 0, B0
· RETURN
Note: Using this code is the only time I think using internal variable names is appropriate.
Jon Williams
Post Edited (Jon Williams (Parallax)) : 6/24/2005 11:13:23 PM GMT
Do you mean something like this;
'{$STAMP BS2}
'{$PBASIC 2.5}
temp0·· VAR· Byte
temp1·· VAR· Byte
temp2·· VAR· Byte
temp3·· VAR· Byte
temp4·· VAR· Byte
temp5·· VAR· Byte
index·· VAR· Byte
bob0··· VAR···· temp0
bob1··· VAR···· temp1
bob2··· VAR···· temp2
bob3··· VAR···· temp3
bob4··· VAR···· temp4
bob0· = $11
bob1· = $22
bob2· = $33
bob3· = $44
bob4· = $55
FOR index = 0 TO 4······················ 'debug shows 11 to 55
·· temp5 = temp0(index)
·· DEBUG·· "temp5=",HEX2 temp5,CR
·NEXT
FOR index = 0 TO 4·······················'debug shows 10 then 11 (didn't do all them)
··· temp0(index) = index +$10
NEXT
DEBUG "temp0=", HEX2 temp0,CR,"temp1=",HEX2 temp1,CR
I think this will do what I want, neat trick. Thanks for your help.
Bob
