IR Communication With PDA
Hello,
· I have just recently purchased the What is a microcontroller book with stamp.
·I have one project in mind for what I want to do and is the sole reason to purchase the book. Here goes:
·I have a Palm One pda and a Pocket PC(jornada 540) I want to be able to write a program onto the basic stamp and use the pda as if it were an lcd or the debug window. So that I can create programs or menus to be viewed on the pda. either one would work. Now if I can do this through serial it would be great, but I have high goals and would like to make the connection viz infrared.
Can someone please tell me how I can do this?
Post Edited By Moderator (Chris Savage (Parallax)) : 6/24/2005 5:31:52 PM GMT
Search the Parallax website...they have a 'free to download' book on IR and such. Should give you a good idea on how to do some things.
Maybe start with doing it serially....although it might not work serially if you are using USB (not sure how well a USB>rs232 converter would work).
Is it doable....yes.
You would need to have a IR transmitter on the stamp side.
If you want the PDA to talk back to the stamp...you'll then need an IR receiver.
( http://www.hvwtech.com/pages/products_view.asp?ProductID=166 )
IF you need to send something then immediatly listen....keep in mind that it takes time to load functions on the stamp. So when you do a SEROUT (send data to the PDA) and then switch immediately to a SERIN (to listen and see if an error message was sent back from the PDA) it takes time to load the SERIN function. So you may end up decreasing the baud rate....
Someone else can jump in and correct me!
Steve
http://ca.geocities.com/steve.brady@rogers.com/index.html
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
[noparse][[/noparse]url]Http://www.parallax.com[noparse][[/noparse]/url]
peter
Peter C. Charles
Director, Research and Technology
CyberBiota, Incorporated
Peter.charles@cyberbiota.com
http://www.cyberbiota.com
This will give you IrDA right from the Stamp through an external UART, which will probably do exactly what you want. Here is the link: http://www.emesystems.com/BS2IrDA.htm . Thanks go to Dr. Tracy Allen - Stamp Guru extrodinaire!
Bruce Bates
