stepper motor wiring
An acquaintance of mine took a look at my stepper motor wiring and insisted that I should be connecting the leads via diodes to the common and even showed me a diagram at a university electronics lab page that has that happen.
I tried disputing him, but am wondering if I might as well add those diodes?· Would they do any good?· Should I connect them betwen the leads and the 12 v common?
thanks
bob
thanks
bob
· http://www.parallax.com/detail.asp?product_id=500-00005
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
[noparse][[/noparse]url]Http://www.parallax.com[noparse][[/noparse]/url]
Post Edited (Dave Andreae (Parallax)) : 6/24/2005 2:28:02 PM GMT
Sorry, I forgot to mention that I am using the ULN 2803 already.· I want to know how to add diodes to that circuit.
bob
If you're already using the ULN200x to drive the stepper motor, you will note on the data sheet that there are integral supression diodes built into the chip. No need to add additional diodes.
Bruce Bates
csavage@parallax.com
There are schematics that use diodes on each line to the power supply so that any back EMF (ElectroMotive Force) is not routed to the drive chip.
http://www.allegromicro.com/demo/a3977sed/schematic.pdf
look at the far right, center of the schematic. the output lines are to a Bi-polar (4 wire) motor.
But, that driver chip, the Allegro A3977 is rated for 35 volts and 2.5 amps. probably quite a bit more than you are using.
If you read the thead of NewZed about torque, the Gecko driver is rated for 80 volts and 7 amps, but the chips on the board are rated for 100 volts and 10 amps. the de-rating eleminates the problems associated with back EMF.
Dave
Dave
Some stepper motors have the diodes already inside their housing.· If you buy or are consider buying an undocumented stepper, you should Google to find out what is inside it.
This grows more common with the larger more powerful steppers.
Otherwise, you may be assuming that everything is simply a few standard configuratons.
Fortunately, once you see how the diodes are configured, they are working for you and not against you.· You don't have to by-pass or modify them.· You just need to understand how to properly use them.
G. Herzog in Taiwan
