problem with writing register to ADC AD7730
·· I am doing a project on blood pressure measurement. currently i am doing signal conditioning part. i am trying to write register into AD7730(or AD7714 or any other chip with serial interface). it is very strange that sometimes it works only for some certain register. that means i can see RDY goes low and i can start reading register. i am using SHIFTOUT command. i am afraid of time requirement cannot be matched with AD7730. can anyone help to look at my code below? i try with clock polarity =1 but still cannot.
thank you very much
' P0 -- SCLK, P1 -- RDY, P2 -- DIN, P3 -- DOUT, P4 -- CS
' {$STAMP BS2}
OUTPUT 0
OUTPUT 3
OUTPUT 4
INPUT· 1
INPUT· 2
LOW 0
HIGH 3
HIGH 4
LOW 4
SHIFTOUT 3,0, MSBFIRST, [noparse][[/noparse]reset1\16, reset2\16]
HIGH 3
HIGH 4
LOW 0
PAUSE 1
LOW 4
SHIFTOUT 3,0, MSBFIRST, [noparse][[/noparse]WRITEmode\8]
HIGH 3
HIGH 4
LOW 0
PAUSE 1
LOW 4
SHIFTOUT 3,0, MSBFIRST, [noparse][[/noparse]regmode\16]
HIGH 3
HIGH 4
LOW 0
PAUSE 1
LOW 4
SHIFTOUT 3,0, MSBFIRST, [noparse][[/noparse]READmode\8]
HIGH 3
HIGH 4
LOW 0
AGAIN:
IF IN1=0 THEN below
GOTO AGAIN
below:
LOW 4
SHIFTIN 2,0, MSBPOST, [noparse][[/noparse]result\16]
SHIFTIN 2,0, MSBPOST, [noparse][[/noparse]dummi\16]
LOW 0
HIGH 4
DEBUG HEX result
code below cannot work
PAUSE 1
LOW 4
SHIFTOUT 3,0, MSBFIRST, [noparse][[/noparse]readstatus\8]
HIGH 3
HIGH 4
LOW 0
wieder:
IF IN1=0 THEN unter
GOTO wieder
unter:
LOW 4
SHIFTIN 2,0, MSBPOST, [noparse][[/noparse]result2\8]
LOW 0
HIGH 4
DEBUG " status register is "
DEBUG HEX result2
thank you very much
' {$STAMP BS2}
OUTPUT 0
OUTPUT 3
OUTPUT 4
INPUT· 1
INPUT· 2
LOW 0
HIGH 3
HIGH 4
LOW 4
HIGH 3
HIGH 4
LOW 0
PAUSE 1
LOW 4
HIGH 3
HIGH 4
LOW 0
PAUSE 1
LOW 4
HIGH 3
HIGH 4
LOW 0
PAUSE 1
LOW 4
HIGH 3
HIGH 4
LOW 0
AGAIN:
IF IN1=0 THEN below
GOTO AGAIN
below:
LOW 4
LOW 0
HIGH 4
DEBUG HEX result
PAUSE 1
LOW 4
HIGH 3
HIGH 4
LOW 0
wieder:
IF IN1=0 THEN unter
GOTO wieder
unter:
LOW 4
LOW 0
HIGH 4
DEBUG HEX result2
1. PBASIC programs almost never need to use the OUTPUT and INPUT keywords -- the commands (like·HIGH, LOW, etc.)·handle this automatically.· There are a few exceptions, but as I just stated, they are exceptions.
2. Using named pins will help others help you.· Since you didn't provide a schematic, the only thing we can deduce from your code is that P3 is the data out, and P0 is the clock out.
3. You definitely want to use POL = 1 because that's how the SHIFTIN and SHIFTOUT clock works.
Jon Williams
A good deal needs to be done to the supplied program before it will pass through the Stamp Editor without errors. I suspect even more will need to be done before you are successful in using it with the ADC7730. I found no reference to the ADC7714 on the Analog Devices web site, so I reserve comment on that chip.
Here is a copy of the program with the undefined areas outlined, and at least some rudimentary comments added. You will find that troubleshooting ANY program will be much easier if you add comments to it.
' {$STAMP BS2}
OUTPUT 0 'CLK
INPUT 1 'RDY
INPUT 2 'DIN
OUTPUT 3 'DOUT
OUTPUT 4 'CS
reset1 VAR Word 'UNDEFINED in supplied program! *
reset2 VAR Word 'UNDEFINED in supplied program! *
READmode VAR Word 'UNDEFINED in supplied program! *
WRITEmode VAR Word 'UNDEFINED in supplied program! *
regmode VAR Word 'UNDEFINED in supplied program! *
result VAR Word 'UNDEFINED in supplied program! *
result2 VAR Byte 'UNDEFINED in supplied program *
dummi VAR Word 'UNDEFINED in supplied program! *
readstatus VAR Byte 'UNDEFINED in supplied program! *
'Begin Chip Initialization Sequence
LOW 0 'Bring CLK LOW
HIGH 3 'Bring DOUT HIGH
HIGH 4 'Bring CS HIGH
LOW 4 'Bring CS LOW
'End Chip Initialization Sequence
SHIFTOUT 3,0, MSBFIRST, [noparse][[/noparse]reset1\16, reset2\16] 'Send unknown data to ADC
HIGH 3 'Set DOUT HIGH
HIGH 4 'Set CS HIGH
LOW 0 'Set CLK LOW
PAUSE 1 'Wait for chip to settle
LOW 4 'Set CS LOW
SHIFTOUT 3,0, MSBFIRST, [noparse][[/noparse]WRITEmode\8] 'Send unknown data to ADC
HIGH 4 'Set CS HIGH
LOW 0 'Set CLK LOW
LOW 4 'Set CS LOW
SHIFTOUT 3,0, MSBFIRST, [noparse][[/noparse]regmode\16] 'Send unknown data to ADC
HIGH 4 'Set CS HIGH
LOW 0 'Set CLK LOW
LOW 4 'Set CS LOW
SHIFTOUT 3,0, MSBFIRST, [noparse][[/noparse]READmode\8] 'Send unknown data to ADC
HIGH 4 'Set CS HIGH
LOW 0 'Set CLK LOW
AGAIN:
IF IN1=0 THEN below 'Check RDY pin on chip
GOTO AGAIN
below:
LOW 4 'Set CS LOW
SHIFTIN 2,0, MSBPOST, [noparse][[/noparse]result\16] 'Receive data into UNDEFINED location
SHIFTIN 2,0, MSBPOST, [noparse][[/noparse]dummi\16] 'Bypass 16 additional bits of data to UNDEFINED location
LOW 0 'Set CLK LOW
HIGH 4 'Set CS HIGH
DEBUG HEX result 'Display result on DEBUG terminal in HEX - 2 bytes of data
LOW 4 'Set CS LOW
SHIFTOUT 3,0, MSBFIRST, [noparse][[/noparse]readstatus\8] 'Send unknown data to ADC - 8 bits ONLY
HIGH 4 'Set CS HIGH
LOW 0 'Set CLK LOW
wieder:
IF IN1=0 THEN unter 'Check RDY pin on chip
GOTO wieder
unter:
LOW 4 'Set CS HIGH
SHIFTIN 2,0, MSBPOST, [noparse][[/noparse]result2\8] 'Receive data into UNDEFINED location
LOW 0 'Set CLK LOW
HIGH 4 'Set CS HIGH
' Display Status Regster on DEBUG Terminal
DEBUG HEX result2
END
I made no attempt to check the logic of the program since the data areas indicated were not defined. I did note that some commands require 8 bits of data, some use 16 bits, and others use 24 bits, so be careful to supply the appropriate number of bits of data for the operation involved. Note also that an external master clock is required for this chip.
The chip can be used in SPI mode using only three wires, which is probably the way to go, at least during the early development stage. All that is required to communicate with the chip are SCLK, DIN, and DOUT. _CS can be tied LOW, and POL tied as appropriate. _SYNC and _RESET can both be tied HIGH.
Bruce Bates
I'm using AD7730 in weigh scale applications,here is example codes of writing and reading of registers:
ADdata······· var··· word······· 'variable to hold 16 bit result.
DATAin····· con····· 2············'AD data input pin.
DATAout····con···· 3··········· 'AD data output pin.
SCKL··········· con···· 4··········· 'clock to AD.
RDY············· con···· 5··········· 'RDY input .
input 5
Initial:
SHIFTOUT DATAin,SCLK,MSBFIRST,[noparse][[/noparse]$FFFF\16,$FFFF\16] 'write 32 ones will reset the AD7730 to the default state.
SHIFTOUT DATAin,SCLK,MSBFIRST,[noparse][[/noparse]$02] 'write to communication register setting next operation as write to mode register.
SHIFTOUT DATAin,SCLK,MSBFIRST,[noparse][[/noparse]$3080\16] 'write to mode register starting continuous conversion for 10mV input range,unipolar,16 bit data word and 5V reference.
SHIFTOUT DATAin,SCLK,MSBFIRST,[noparse][[/noparse]$21] 'write to communication register setting next operation as continuous read from data register.
low 2············· ' set DIN line low to insure part is not reset while in continuous reade mode.
ReadData:
waitRDY:
IF RDY = 1 THEN waitRDY············ 'wait for RDY to go low to indicate output update.
SHIFTIN DATAout,SCLK,MSBPOST,[noparse][[/noparse]ADdata\16]······ 'read conversion result from data register.
DEBUG DEC ADdata,cr········· ·'display data in decimal.
pause 500·································· 'wait 0.5 second between reading.
GOTO ReadData
Regards
Mohamed Refky
