Using a keypad and an LCD display
Hello,
· I am trying to find a keypad/LCD combination for use in a project with the BS2.· I need at least 8 keys, and an LCD of 16x2 or greater.· Ideally, the unit would have a serial/TTL output so that I could read the input of the system with only a few pins of the BS2.· Also, the key illustrations must be customizeable.· Has anyone run across such a device?
thanks,
Andrew
thanks,
Andrew
Sid Weaver
Do you have a Stamp Tester yet?
·· There are several LCD Displays available on our website under accessories.· There are a few with keypad decoders, but there are also plenty of KeyPad Decoder chips available that can output serial data.· As for customizable keypad definitions, B.G. Micro sells keypads with customizable legends.
csavage@parallax.com
http://www.matrixorbital.com/product_info.php?pName=lk16212&cName=lcd-character-lcds for the product, http://www.matrixorbital.ca/Manuals/LK_series/LK162-12/LK162-12_220.pdf for the manual. You can interface a stamp with the display quite easily. Some examples are shown at http://www.matrixorbital.ca/appnotes/basic_stamp/ .
Best Regards,
Tom Lam
http://www.robot-electronics.co.uk/shop/I2C_Serial_Display_LCD022058.htm
and a code sample here
http://www.robot-electronics.co.uk/htm/lcd02bs2p.htm
expensive, but easy to code
good luck
Walter
· Thanks for the link.· The price is listed in pounds.· How much did it cost you for the set in dollars?
thanks,
Andrew
this is where you order it from.
http://www.acroname.com/robotics/parts/R234-LD02.html
Walter
