A STAMP, A pump, and lots of patience....
OK, so the whole pump thing has changed once again. for those of you unfamiliar with the trails and tribulations of the pump controlled STAMP input, I'll summarize: Ive tried many things, and many things have worked. And yet the only truth is change, so here I am. I'm now trying to accomplish a very simple task: pump goes up, triggers an input signal to STAMP, pump goes down, it triggers a different signal. I have in my hands two 12VDC micro fans, and when they spin, they induce about .006 volts. That’s a very small voltage, and I can’t get a reading on Amps or resistance. Any ideas on how I could get this wee voltage to trigger a logic signal to the STAMP? I promise this will be the last revision!
Jon Williams
Maybe a microswitch with a little foil sail to catch the moving air and trigger. As far as the direction....put one on both sides....the fan blades only let air flow in one direction.
Another idea would be to use some temperature sensors. One in the front of each fan and one as a reference in teh enclosure. Then compare each fans' temp sensor with the reference to see if the wind is going across it and cooling it.
Steve
http://ca.geocities.com/steve.brady@rogers.com/index.html
·· Jumping into this a little late, but it occurred to me that if the fans you're using are the little muffin fans, like ones used in computer cooling, they don't give any real good output voltage from being turned like a standard brush motor would.· Perhaps if you had a fan blade attached to a brush-type motor you would get a higher voltage which could be more easily read by the Stamp,·possibly without amplification.· Just a thought.
csavage@parallax.com
Your idea of using a pressure sensor is probably the best way. I have used these before and they are pretty straight forward. You can find them in many configurations for around $20.00 from Digikey. They are preamplified so you would need only an A to D converter. You can set it up to measure differential pressure so you could tell whether the bellows was pulling air or pushing it.
Lee
