HomeWork Board fried ?
I just received the "What's a microcontroller" kit today which comes with the BS2 HomeWork Board.·· I hooked it up with a brand new duracell 9v and nothing is happening, the power light doesn't come on and the PBasic editor doesn't detect it, it shows the echo & loopback but doesn't identify the board.
I'm running windows 2000, I turned the FIFO's off as suggested in another thred.··· What now ?
My suggestion is to check the voltage on the homework board with the battery connected. The voltage should·read at least· 7 volts, and if the battery is in good shape, even higher.
·· Definately try another battery...The green LED should come on as soon as the battery is plugged in.
csavage@parallax.com
·· Please contact Tech Support at 1-888-997-8267 between 7A-5P Pacific Time.
