Project: Any Transmitter/ Receiver recommends
Hi Sir,
I'm currently doing my personal project. I'm trying to search for a kind of Transmitter/ Receiver··device.
Follows are my requirement for this device:
1. Transmit Range up to 50 feets.
2.·For·download the PBasic Code·from PC·into·microcontroller.
3. Best Price.
Appreciate your help
New1976
3. Best Price.
New1976
Thanks for prompt responds.
I have actually has·doubt on·how to·choose the right RF modules for my personal project. I have two RF modules in minds as shown below:
1. 0169-Par-YES Wireless TxRx Qty 2
2. PX27987 433 MHz RF Module·Receiver· 1 unit···
··· PX27986 433 MHz RF Module Transmitter· 1 unit
I basically need a RF module to replace the serial cable. The downloading of the Pbasic code will be done on the computer screen. In order words, there is no cable connection·between computer to the board.
So can·anyone give me a·suggestion on which RF modules to choose as stated above.
Appreciate your advise.
New1976·
·· I am not aware of an RF module which, as packaged will do what you require.· Programming of the Stamp requires the DTR line to be available, as well as the device being able to duplicate the "break" condition, also required to program a Stamp Module.· There are very strict timing requirements, which can be found in our tokenizer library documentation on our website.
csavage@parallax.com
A new wireless standard called wireless USB (wUSB) is coming out on the market, in theory it communicates USB data wirelessly. So if you have a USB based Stamp board, you could theoretically use two wireless USB modules to communicate between your stamp and PC. But here is the major caveat: I have not studied the details of wUSB, therefore I do not know if wUSB is 100% compatible with standard USB. Also as Chris mentions there are strict timing requirements, droping a wUSB link in the mix will most certainly increase the latency of the signal (the time it takes for the data to travel from the PC to the stamp (and back to the PC)) which may cause the Stamp IDE's failure to properly recognize the stamp. So before deciding on this route, extensively study wUSB specs paying particular attention to compatability with standard USB and the time it takes for USB data entering the wireless link to exit the wireless link on the destination module. This would require you finding out what the timing requirements are for programming the stamp to ensure that adding the wireless portion won't foul the timing up.
Thanks for your advise.
I'm using a Boe Bot Robot Kit and the board i'm using now is in Serial port rather than USB. As for the USB(wireless) is the product available now in market? Cos i have deadline to do implements this into my project.
If USB(wireless) is not available for the time being. I would to use the RF module. So is a advisable to use the RF module to act as a wireless.
The most important i want to achieve for this project is that, I want to replace the Serial programming Cable into some wireless devices. With this i can perform a PBasic code downloading to the Basic stamp from the computer without using the cable.
New1976
http://www.electrowave.com/products/stamper.shtml
