servo to use to pan a sonar ping
·I am planning on building a pan/servo setup for my ping sonar ranger. I'm wondering wich would be better, a cont rotaion servo, or a regular hobby servo 180<> servo. I guess me biggest concern is weather I can keep them on· track. I do not want·it to get out of line to much to the left, or right after it runs a few times. So if anyone has any recomendations it would be greatly apriciated..· Thanks _Duane
It was used as a proximity sensor on a robot. Unfortunately, the 24 inch detection range was inadequate. Sometimes, the obstacle could sneak up on the robot if the sensor sweep was just in the wrong time sequence. With a longer distance sensing Ping, this may not be a problem. However, your sweep rate needs to consider the time it takes for the sound to travel to and from the obstacle.
