serout with start bit, 8 data bits, stop bit
Hello All. I have been trying this morning to serially control a Compact Flash digital video player, the MedeaWiz DV-66 with a BS-2. It's specs call for 4800 baud, 1 start bit, 8 data bits, 1 stop bit, at TTL levels.·I·have·not had any success. I suspect that the start bit is the trouble. The DV-66 communication·protocol can be found at http://www.teamkingsley.com/assets/userguide9-04.pdf·and the data waveform at http://www.teamkingsley.com/assets/DV66K_spec.pdf
I am trying to send data just like the above waveforms for track 1 to track 3.··I have tried to toggle the bit just before serout, tried SEROUT· 7, 16572, [noparse][[/noparse]sbit,HEX 3]··· '16572 or 188·· where sbit is a nib var set to %0 to act as a start bit, tried inverting the data, tried storing the data in a byte var as %00000010·then serout the var, tried reversing the 8 data bits (msb first, lsb first). I have a 10K pullup on pin 7, the serout pin. The DV-66 is responding to the data that I send, but it does not recognize it as a valid command and reverts to the beginning of track 1 each time I try to send a command.
I·know there is a very simple solution...I just can't yet see it. Any help would be greatly appreciated
Bill Kingsley
Bill Kingsley
SEROUT 7, 16572, [noparse][[/noparse] 3 ] should play track three. It's the 'HEX' modifier you don't need -- that 'expands' the three into the characters "0" "3" -- when the player wants the BYTE '3'.
And if it doesn't, then SEROUT 7, 188, [noparse][[/noparse] 3 ] should work. That 'Invert' vs 'Don't Invert' is pretty tricky. Just try both.
P.S. my 'bracket' 3 'bracket' keeps getting eaten...
#SELECT $STAMP
· #CASE BS2, BS2E, BS2PE
··· T1200······ CON···· 813
··· T2400······ CON···· 396
··· T4800······ CON···· 188
··· T9600······ CON···· 84
··· T19K2······ CON···· 32
··· TMidi······ CON···· 12
··· T38K4······ CON···· 6
· #CASE BS2SX, BS2P
··· T1200······ CON···· 2063
··· T2400······ CON···· 1021
··· T4800······ CON···· 500
··· T9600······ CON···· 240
··· T19K2······ CON···· 110
··· TMidi······ CON···· 60
··· T38K4······ CON···· 45
· #CASE BS2PX
··· T1200······ CON···· 3313
··· T2400······ CON···· 1646
··· T4800······ CON···· 813
··· T9600······ CON···· 396
··· T19K2······ CON···· 188
··· TMidi······ CON···· 108
··· T38K4······ CON···· 84
#ENDSELECT
SevenBit······· CON···· $2000
Inverted······· CON···· $4000
Open··········· CON···· $8000
Baud··········· CON···· T4800
I edited the Baud constant for T4800 -- copy this block and put it into your program and it should work for you, regardless of which BS2-family module you have installed.
Jon Williams
Bill Kingsley
Bill Kingsley
187 -> 4830
188 -> 4807 Baud
189 -> 4784
So, it looks like 23 Hz per BaudModeSelect value at that frequency.
Note that 'stock' RS-232 is supposed to accept a drift of 10%, that's why we have start bits and stop bits, after all. It is supposed to 're-sync' itself on the start of each byte.
Oh, and the "works 70% of the time" bug can be caused by a poor, or missing, ground wire, connected to both sides.· Especially when it's TTL level RS-232, you MUST have a good ground wire.
Still maybe something on their end is nit-picky ... you can always tweak the baudmode value up one to see if that helps.
Theory:
187 on BS2 = 4831 baud (+0.65% error)
188 on BS2 = 4807 baud (+0.15% error)
189 on BS2 = 4784 baud (-0.33% error)
As you can see 188 is real doggone close -- close enough that it should work when the receiver is reliable.· I would bet that it is the bit timing on their end that is the problem.
Jon Williams
Although it won't help with bit error rates or bit timing, sometimes you can get some mileage out using data pacing to slow up the (byte) data just a little. There's certainly no harm in trying it. Data pacing can be found in the SEROUT command as a sub-parameter.
Bruce Bates
Jon Williams
I'm coming in late in this conversation and don't have time to read it all (someone clued me into this thread) but thought of posing the following questions:
1) Have you ever tried it without the 10K pullup resistor on SOUT?· I'm not sure why you have it there, but most connections don't require an external pullup resistor because the receiving device itself should have one already (else it would receive garbage all the time when nothing is connected).
2) Are you sure that you need to send a 1?· I mean a binary 1?· Perhaps the docs are really suggestion an ASCII 1, ie: "1" which is decimal 49.
Hope this is of some help.
--Jeff
--Jeff Martin
· Sr. Software Engineer
· Parallax, Inc.
Hmm. If he really does have a 10K pull-up in there, maybe he does need one of the 'open' modes. Or he shouldn't have the 10K pull-up in there. Which "Vdd" is the 10K tied to? I'm still betting on either bad grounding, or trying to send TTL RS-232 too far (10 feet might be too far). How far away is the BS2 from the device it's trying to control?
I know you said TTL levels but could a line driver be the differance
check to see if the command is sent twice or just try it
'Serial comm test for MedeaWiz DV-66 digital video player using
'Parallax Basic Stamp model BS2
'Beta Version, not for distribution
'6/22/05 Team Kingsley LLC
'www.teamkingsley.com
'{$STAMP BS2}
'187 on BS2 = 4831 baud (+0.65% error)
'188 on BS2 = 4807 baud (+0.15% error)
'189 on BS2 = 4784 baud (-0.33% error)
'190 on BS2 = 4761 baud (-0.81% error)
'191 on BS2 = 4739 baud
'192 on BS2 = 4716 baud
'193 on BS2 = 4694 baud
'we have not yet determined the optimal "actual baud rate"
'however this code works very well...
Top:
SEROUT 7, 193, [noparse][[/noparse]1,1,1,1] 'using I/O 7 to xmit to DV-66
'send byte 4 times
PAUSE 5 'wait a few Ms before debug out
DEBUG CLS, "Track 1" 'show track number on PC screen
PAUSE 15000 'play track for 15 seconds
SEROUT 7, 193, [noparse][[/noparse]2,2,2,2] 'using I/O 7 to xmit to DV-66
'send byte 4 times
DEBUG CLS, "Track 2" 'show track number on PC screen
SEROUT 7, 193, [noparse][[/noparse]3,3,3,3] 'using I/O 7 to xmit to DV-66
'send byte 4 times
DEBUG CLS, "Track 3" 'show track number on PC screen
PAUSE 8000 'play track for 8 seconds
SEROUT 7, 193, [noparse][[/noparse]246,246,246,246] 'pause 'send byte 4 times
PAUSE 5000 'still-frame for 5 seconds
SEROUT 7, 193, [noparse][[/noparse]247,247,247,247] 'play 'send byte 4 times
PAUSE 5000 'continue play for 5 seconds
GOTO top 'go to top and do it all again
END
Note that you could edit you code more easily by using named constants instead of embedded values.· For example:
TX·······PIN··· 7
Baud···· CON··· 193
cmd····· VAR··· Byte
delay··· VAR··· Word
idx······VAR··· Nib
Main:
· FOR idx = 0 TO 4
··· LOOKUP idx, [noparse][[/noparse]1, 2, 3, 246, 247], cmd
··· LOOKUP idx, [noparse][[/noparse]15, 15, 8, 8, 5], delay
··· delay = delay * 1000
··· GOSUB Send_Cmd
··· PAUSE delay···
· NEXT
· GOTO Main
Send_Cmd:
· SEROUT TX, Baud, [noparse][[/noparse]cmd, cmd, cmd, cmd]
· RETURN
I know you're just testing things at the moment, but I'm a very big believer that test code can be ported to production code and save a lot of rework -- it just takes a little planning.
Jon Williams
