SX-key v3.10 bug?
Hello,
During playing with the SX-key v3.10 software, i found some strange thinks, bug?:·every time you push on the Device button in the main menu, en left the Device window with cancel, you get an extra item called ‘Device Windows ·Ctrl I’,· under Windows.
Regards, Rob
Regards, Rob
Yes, that's a bug all right. It just shows how many people ever use the "Windows" menu in the IDE. I'll look into what is happening and fix it. It will get released when there are enough bug fixes or changes to warrant a new release.
Thanks, PeterM
If you're going to be into it, I noticed that in debug I can't set the break point at the last line of code; not a big deal but.....
Peter (pjv)
I'll add it to the list.
Thanks, PeterM
