Surelink 900mHz
I want to control the channel that I am using on a couple of Surelink 900mhz.· Is it possible to swith Pins 5 and 6 to low or high from a Basic pin so that you can control which channel the two cards are using?· I want to be able to relay a 'transaction' from one card to another so that I can increase the distance from the point of origination to the final contact point.· Any sample code would also help.· Thanking you in advance, Clayton Fowler
DTQ
anyways if you dont get a chance to try it I give it a try in the next few days. neat idea though
DTQ
