BOE Power Switch
Can anyone tell me if there is an obvious way to by-pass the power switch on the BOE.
I would like to add a small toggle switch to an exterior case so that the actual board does not need to be accessed.
Sid Weaver
Need a bezel for your LCD?
Newzed@aol.com
Sid Weaver
Newzed@aol.com
Sid
Pete
·· The power switch is a DPDT switch.· There are also 3 positions.· The easiest way to do this would be to splice the + line on the power lead being plugged into the board, and interrupt it's power.· One line is being broken, and that line is being switched.· Very simple, and no modifications to the board are necessary.
csavage@parallax.com
Sid
Sid,
·· Read back a little ways...
That is, I would assume, a Wall-Wart.
The idea will be to literally splice the the + line before it is plugged into the BOE - adding the toggle here?
Post Edited (Paul Baker) : 6/14/2005 9:39:36 PM GMT
Pete
·· I was trying to provide him with the least complicated way to do this, while also not having to "hack" his BOE.· If you've ever seen those AC power cord·switches that allow you to add a switch to an AC appliance that doesn't have·a switch.· They typically work by splicing the main line, they interrupt one of the wires, and switch it.· This would be similar, and ideal to adding the power switch to the cabinet with very little work.
Post Edited (Paul Baker) : 6/14/2005 10:02:30 PM GMT
