Math (Float32) Problem
Hi all,
I purchased a uM-FPU Coprocessor Version 2.0 and am attempting
to run the associated demo files from here under Applications.
The Float32.java compiles to Float32.class but any of the example
program seem unable to locate it.· I am reasonable sure that it is
in the correct location to be found and importing the right packages.
This is probably a very simple problem but for right now it has me whipped.
Thanks in advance for all your much needed assistance.
Carey
CarSta
Carey
CarSta
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
[noparse][[/noparse]url]Http://www.parallax.com[noparse][[/noparse]/url]
I just didn't understand that the path had to be the
same as in the install (Unzip).· Works fine now.
I also purchased the uP-FPU and that is doing the same program in hardware.
The communications problems I was having has been completely cured with the
Javaline.· We are currently in production, with a prototype working great.
Thanks again,
CarSta
Carey
