RF switch?
Hello, I need a switch that can sense when one circuit or component gets close to another circuit or component. It needs to be able to sense within a 5 inch diameter, more or less. For instance, if I had a necklace around my neck, and got within 5 inches of the sensor, then a high input signal gets sent to stamp. If there was such thing as a very sensitive hall effect sensor, that would work- but I dont think it would be within my price range. Any ideas?
How about a low-output modulated IR beacon on one circuit and a detector/demodulator on the other. It should be relatively inexpensive and well within the capabilities of the Stamp. The only difficulty would by the geometry of the emitter/detector and the possibility that it would be too sensitive. What, precisely, are you trying to accomplish?
peter
Peter C. Charles
Director, Research and Technology
CyberBiota, Incorporated
Peter.charles@cyberbiota.com
http://www.cyberbiota.com
5 inches can easily be done with a Hall effect sensor and a NIB magnet, and cheaply. Look for one with a linear output and use an op amp and comparator to adjust range and sensitivity. Allegro makes a lot of good Hall effect sensors. If you don't need security ID, this would be very easy to implement and the coding a breeze.
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
