save data in another program
I'm using sht11 sensor to measure temp, the program below outputs data on debug window. how can I save (send) this data to another program like Text editor or Excel?
' File...... SHT11_Demo.BS2
' Purpose... Interface to Sensirion SHT11 temperature/humidity sensor
' Author.... Parallax
' E-mail.... support@parallax.com
' Started...
' Updated... 19 JUL 2003
' {$STAMP BS2}
' {$PBASIC 2.5}
' Program Description
' This program demonstrates the interface and conversion of SHT11/15 data
' to usable program values. This program uses advanced math features of
' PBASIC, specifically the ** operator.
' For detailed application information on the use and application of the
' ** operator, see Dr. Tracy Allen's web page at this link:
' -- http://www.emesystems.com/BS2math1.htm
' For SHT11/15 documentation and app notes, visit:
' -- http://www.sensirion.com
' Revision History
' I/O Definitions
ShtData PIN 1 ' bi-directional data
Clock PIN 0
' Constants
ShtTemp CON %00011 ' read temperature
ShtHumi CON %00101 ' read humidity
ShtStatW CON %00110 ' status register write
ShtStatR CON %00111 ' status register read
ShtReset CON %11110 ' soft reset
Ack CON 0
NoAck CON 1
No CON 0
Yes CON 1
DegSym CON 186 ' degrees symbol for DEBUG
' Variables
ioByte VAR Byte ' data from/to SHT11
ackBit VAR Bit ' ack/nak from/to SHT11
toDelay VAR Byte ' timeout delay timer
timeOut VAR Bit ' timeout status
soT VAR Word ' temp counts from SHT11
tC VAR Word ' temp - Celcius
tF VAR Word ' temp - Fahrenheit
soRH VAR Word ' humidity counts
rhLin VAR Word ' humidity; linearized
rhTrue VAR Word ' humidity; compensated
status VAR Byte ' status byte
' EEPROM Data
' Initialization
Initialize:
GOSUB SHT_Connection_Reset ' reset device connection
PAUSE 250 ' let DEBUG window open
DEBUG CLS,
"SHT11 Sensor Demo", CR,
", CR
' Program Code
Main:
DO
GOSUB SHT_Measure_Temp
DEBUG CRSRXY, 0, 3,
"soT...... ", DEC soT, CR,
"tC....... ", DEC (tC / 10), ".", DEC1 tC, DegSym, " ", CR,
"tF....... ", DEC (tF / 10), ".", DEC1 tF, DegSym, " "
GOSUB SHT_Measure_Humidity
DEBUG CRSRXY, 0, 7,
"soRH..... ", DEC soRH, CR,
"rhLin.... ", DEC (rhLin / 10), ".", DEC1 rhLin, "% ", CR,
"rhTrue... ", DEC (rhTrue / 10), ".", DEC1 rhTrue, "% "
PAUSE 1000
LOOP
END
' Subroutines
' connection reset: 9 clock cyles with ShtData high, then start sequence
SHT_Connection_Reset:
SHIFTOUT ShtData, Clock, LSBFIRST, [noparse][[/noparse]$FFF\9]
' generates SHT11 "start" sequence
' _____ _____
' ShtData |_______|
' ___ ___
' Clock ___| |___| |___
SHT_Start:
INPUT ShtData ' let pull-up take high
LOW Clock
HIGH Clock
LOW ShtData
LOW Clock
HIGH Clock
INPUT ShtData
LOW Clock
RETURN
' measure temperature
' -- celcius = raw * 0.01 - 40
' -- fahrenheit = raw * 0.018 - 40
SHT_Measure_Temp:
GOSUB SHT_Start ' alert device
ioByte = ShtTemp ' temperature command
GOSUB SHT_Write_Byte ' send command
GOSUB SHT_Wait ' wait for measurement
ackBit = Ack ' another read follows
GOSUB SHT_Read_Byte ' get MSB
soT.HIGHBYTE = ioByte
ackBit = NoAck ' last read
GOSUB SHT_Read_Byte ' get LSB
soT.LOWBYTE = ioByte
' Note: Conversion factors are multiplied by 10 to return the
' temperature values in tenths of degrees
tC = soT ** $1999 - 400 ' convert to tenths C
tF = soT ** $2E14 - 400 ' convert to tenths F
RETURN
' measure humidity
SHT_Measure_Humidity:
ioByte = ShtHumi ' humidity command
soRH.HIGHBYTE = ioByte
soRH.LOWBYTE = ioByte
' linearize humidity
' rhLin = (soRH * 0.0405) - (soRH^2 * 0.0000028) - 4
' for the BASIC Stamp:
' rhLin = (soRH * 0.0405) - (soRH * 0.002 * soRH * 0.0014) - 4
' Conversion factors are multiplied by 10 to return tenths
rhLin = (soRH ** $67AE) - (soRH ** $83 * soRH ** $5B) - 40
' temperature compensated humidity
' rhTrue = (tc - 25) * (soRH * 0.00008 + 0.01) + rhLin
' -- simplified
rhTrue = (tC - 250) * (soRH ** $34) + rhLin
RETURN
' sends "status"
SHT_Write_Status:
ioByte = ShtStatW ' write to status reg cmd
ioByte = status
RETURN
' returns "status"
SHT_Read_Status:
GOSUB SHT_Read_Byte ' send command
ackBit = NoAck ' only one byte to read
GOSUB SHT_Read_Byte
RETURN
' sends "ioByte"
' returns "ackBit"
SHT_Write_Byte:
SHIFTOUT ShtData, Clock, MSBFIRST, [noparse][[/noparse]ioByte] ' send byte
SHIFTIN ShtData, Clock, LSBPRE, [noparse][[/noparse]ackBit\1] ' get ack bit
RETURN
' returns "ioByte"
' sends "ackBit"
SHT_Read_Byte:
SHIFTIN ShtData, Clock, MSBPRE, [noparse][[/noparse]ioByte] ' get byte
SHIFTOUT ShtData, Clock, LSBFIRST, [noparse][[/noparse]ackBit\1] ' send ack bit
INPUT ShtData ' release data line
RETURN
' wait for device to finish measurement (pulls data line low)
' -- timeout after ~1/4 second
SHT_Wait:
INPUT ShtData ' data line is input
timeOut = No ' assume no timeout
FOR toDelay = 1 TO 250 ' wait ~1/4 second
IF (ShtData = 0) THEN EXIT
PAUSE 1
NEXT
IF (toDelay = 250) THEN timeOut = Yes ' loop completed = timeout
RETURN
' reset SHT11/15 with soft reset
SHT_Soft_Reset:
GOSUB SHT_Connection_Reset ' reset the connection
ioByte = ShtReset ' reset command
ackBit = NoAck ' only one byte to send
GOSUB SHT_Write_Byte ' send it
PAUSE 11 ' wait at least 11 ms
RETURN
' Started...
' {$STAMP BS2}
' {$PBASIC 2.5}
' Revision History
' I/O Definitions
Clock PIN 0
' Constants
Ack CON 0
NoAck CON 1
No CON 0
Yes CON 1
' Variables
' EEPROM Data
' Initialization
Initialize:
DEBUG CLS,
", CR
' Program Code
Main:
DO
DEBUG CRSRXY, 0, 3,
DEBUG CRSRXY, 0, 7,
PAUSE 1000
LOOP
END
' Subroutines
' _____ _____
' ShtData |_______|
' ___ ___
SHT_Start:
LOW Clock
HIGH Clock
LOW ShtData
LOW Clock
HIGH Clock
INPUT ShtData
LOW Clock
RETURN
SHT_Measure_Temp:
RETURN
' measure humidity
' -- simplified
RETURN
' sends "status"
SHT_Write_Status:
ioByte = status
RETURN
' returns "status"
SHT_Read_Status:
GOSUB SHT_Read_Byte
RETURN
' sends "ioByte"
' returns "ackBit"
SHT_Write_Byte:
RETURN
' returns "ioByte"
' sends "ackBit"
SHT_Read_Byte:
RETURN
SHT_Wait:
PAUSE 1
NEXT
RETURN
SHT_Soft_Reset:
RETURN
Sid Weaver
Need a bezel for your LCD?
Newzed@aol.com
Parallax has just the utility for you: StampDAQ, it is an excel plugin that can be used to aquire up to 10 channels of information from your stamp. Best of all, its free!
1. Add to the last line of your "Initialize" routine:
DEBUG CR,"LABEL,TIME,soT,tC,tF,soRH,rhLin,rhTrue",CR
2. Relace your
DEBUG CRSRXY, 0, 3,
With
DEBUG "DATA,TIME,",DEC soT,",",DEC(tC / 10), ".", DEC1 tC,",",(tF / 10), ".", DEC1 tF,","
3. Replace your
DEBUG CRSRXY, 0, 7,
with
DEBUG DEC soRH,",",DEC (rhLin / 10), ".", DEC1 rhLin,",",DEC (rhTrue / 10), ".", DEC1 rhTrue,CR
That should get you started.
