TEP Window software (compiler and downloader) for BS1/2
hi all,
I am looking out for TEP window software available some time back at URL: http://www.tep.org.uk/stamp.htm
which was compiler and downloader for BS1 or BS2 on W3.1/W95/W98/Windows NT/2000.
Can any one help?
Thanks in advance,
--micropar--
Can any one help?
Thanks in advance,
--micropar--
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
[noparse][[/noparse]url]Http://www.parallax.com[noparse][[/noparse]/url]
Thanks for reply.
I have got couple of 10 years old BS1 modules. Unfortunately your new software 2.2 is not working with these modules in serial mode. Your DOS version works perfactly well with these old, antique, still ticking modules in Parallel mode. But for that, I have to used my old PC/DOS computer, a real bottleneck.
What could be the problem? I will be glad if you suggest any solution.
Few years ago, I had used this TEP software, even under Windows NT/2000, with MAX232 serial to parallel convetor similar to one provided in 2.2 help file. Sadly, I lost these software in Hard Disk crash, without backup.
Thanks in advance,
--micropar--
Dave
Dave Andreae
Tech Support
B1s are in SIP form. Although, I am not aware of REV D or its differance with original earlier versions or when did it gets revised.
Dave
Dave Andreae
Tech Support
And, in the "for what it's worth" department ... the BS1 has always been programmed serially (@ 4800 baud).· The reason we used the printer port in the DOS software is that it outputs TTL levels, so no level conversion circuitry was required on the BASIC Stamp.
Jon Williams
Finally, I got TEP software from some anonymous guy. He didn't disclosed his identity as our all communications are from Parallax official forum and he feared of legal complexities. I wondered how he got my direct e-mail address.
Once again, all those old BS1 modules started working well, even with serial port on Win98. I suppose these modules are working at 2400 BPS, may be the reason for your current version of software failure, since it is working on 4800 BPS, as Jon said.
I am using MAX232 version of serial adapter developed much before your official version of discrete transistorized circuit announced. Only difference is my circuit requires +5v power while your works on drawing power from DTR and RTS lines.
Thanking you all, for nice support and for taking keen interest in Basic Stamp's problems solving.
With best regards,
--micropar--
