Fluffy2 PCB?
Okay; I can't print out .prn files that are in the fluf2pcb.zip folder (and I've already tried every possible way to print it out), the .bmp file that's included is not to scale, and when I try to scale it, it becomes distorted, and I can open up the .brd file in BoardMaker3 DEMO, but it won't let me print because it's a demo version. So I'm asking if someone can provide me with the pcb image, either as an image or a gerber file or something that I can open (I'd prefer either a circuit maker, Gerber or Eagle PCB file please) [noparse]:)[/noparse]
UPDATE: Okay everyone; I just solved my own problem
I used SwiftView to open up the .prn file, and it printed (although very slowly).
Post Edited (Ultimate Dev'r) : 6/12/2005 1:57:24 PM GMT
I used SwiftView to open up the .prn file, and it printed (although very slowly).Post Edited (Ultimate Dev'r) : 6/12/2005 1:57:24 PM GMT
Also, keep in mind that you have to buy printed circuit supplies, build a PIC programer, populate the PCB, and so on. Then, you may find that it will only take the SX Ubicom's software, not the Parallax software [noparse][[/noparse]which is much better].
Additionally, it seemed to be one of those abandoned projects that remains on the Internet. So, you really can't get much help for the dead ends. You just have to carry the ball.
Are you going to lay claim to being the inventor of Fluffy#3? Ubicom seems to think so highly of Parallax's product that it has made them a world distributor and apparently let go of much further development of PIC based programmers in support of the SX-based product.
G. Herzog in Taiwan
Post Edited (Kramer) : 6/16/2005 4:26:15 PM GMT
[noparse][[/noparse]QUOTE]Also, keep in mind that you have to buy printed circuit supplies, build a PIC programer, populate the PCB, and so on.
I already had the parts in my room, so I didn't have to buy much. About how much is the SXKey package go for?
[noparse][[/noparse]QUOTE]Then, you may find that it will only take the SX Ubicom's software, not the Parallax software [noparse][[/noparse]which is much better documented].
?? What do you mean?
http://www.parallax.com/sx/programming_kits.asp
Jon Williams
Jon Williams
Now then; when I try to program an SX28 through ICProg with my Fulffy2 PCB, it programs the device in a split second, then proceeds to verify the device, which takes like 20 seconds, and then it gives me an error saying that the verification failed at 0000h. I know the PCB is put together properly and all voltages are correct; however, I've noticed that when I read the SX28, it shows up as all 0000 instead of all 0FFF. Help?
Jon Williams
When you complain about cost I assume you looked at the complete package with books and a few SX-28s included. There used to be SXKeys available without all the other stuff [noparse][[/noparse]maybe try Digikey or EBay]. But, you really need the books and the software to eventually get into the virtual peripheral concept.
Without his book, you have to go the long route of reading all of Ubicom's technical material. Additionally, they are very, very frugal with explaining how the programing process works. So, you really have to think about it quite a bit.
The guys at Fluffy 2 lost interest a long time ago. The guys at Parallax never were interested in Fluffy 1 or 2. Nonetheless, I enjoyed trying to engineer my own programer as 'black boxes' just drive me crazy. I hafta know or try to know.
When all is said and done though, you are still far behind the leading edge. It is a lot like fooling around with model T's, beautiful stuff - but. . .
G. Herzog in Taiwan
Post Edited (Kramer) : 6/16/2005 4:28:52 PM GMT
Turns out Mouser mislabled the bag of transistors I ordered from them
Ryan
And I have a question about the SX chips; do you have to pull-up all unused I/O pins to VDD like you have to do with PICs?
Jon Williams
a. mess something up
b. have a question
Buy Gunther's book at you will understand all of it.· You technically don't have to use pull up resistors at slow clocking speeds; but if you really want to run the microcontroller all out, you have to make sure the i/o is stable.
And, if you have SX questions - go to the SX forum.
Have you figured out all the hidden commands? Heh... heh...
G. Herzog in Taiwan
