Problem with robot
I just soldered the circuit for my robot and I think there might be a short.· The circuit contains two H bridges and three servos.· It is all point to point soldering so it looks very confusing with many possibilities for shorts.· I know point to point isnt the best method for a small, simple circuit board, but it was what I wanted to do.· So anyway, I set all the H-bridge pins so no current is flowing through them, to try and test the servos.· I connect one servo and give it a command.· Instead of moving how I want it to, it just emits a high pitched noise and doesn't move.· I connected an ammeter and it registered something like 130 mA.· I think that there might be a short somewhere.· I know I am not describing the situation too well and its likely that this isnt enough info for anyone to help but if anyone has an idea of a test I can do or a guess at the problem, I would appreciate it.· I'll try and post a reply to this with info from some of my testing to give anyone helping me a better idea of the problem.
Post Edited By Moderator (Dave Andreae (Parallax)) : 6/12/2005 3:10:01 AM GMT
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
[noparse][[/noparse]url]Http://www.parallax.com[noparse][[/noparse]/url]
· This may be just a choice of nomenclature but you use the word ‘servo’ to describe what you are driving with the H-bridges.· You do not need an H-bridge to drive a servo; it can be driven directly from a stamp.· If you are feeding an actual servo with the output of an H-bridge then you could cause damage to the servo.· A servo has three wires that are addressed as follows.· Red wire positive lead for power, usually between 4 vdc and 7.5 vdc.· Black wire, which is the negative lead for power.· A yellow or white wire for the signal which is a pulse between 1ms and 2ms.· If you are driving just a straight DC motor then you could in fact have a short in your circuit.
· If you could post your schematic and your code you are using, we could assist you better.
· Also download·"What's a Microcontroller" and read Chapter #4 Controlling Motion.· This chapter has is a great tutorial on controlling servos.·
Kevin
Post Edited (Kevin B Slater) : 6/13/2005 6:46:14 PM GMT
