Correct parallel resistor value for Parallax 20MHz resonator
Does anyone know, or can tell me how to determine the correct parallel resistor value for the Parallax 20MHz surface mount resonator item #250-12060 ?
I've look over the datasheet from the website, but I don't see it listed anywhere.
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"If you keep doing what you always did, you'll keep getting what you always got."
Bean.
You probably already saw this.
Maybe it's not that critical, but that is a large difference in resistance.
Could I just use something like 100K ?
Bean.
according to the Ubicom specs, the value of that mysterious resistor depends in the resonator type (either 1 M or 22 k). I don't know which Murata type Parallax is selling under their stock number 250-12060 but they should be able to tell you. I would try the 22 k and see if the oscillator savely starts at power-up (don't forget to test that within a certain temperature range). My experience with the 50 MHz resonator is that the parallel resistor is not that critical at all. Normally, I'm using 10 k but I never had trouble when leaving it away.
Greetings from Germany,
G
Bean.
