Stack Trace is corrupt
[noparse][[/noparse]Error IDE -0015] Stack Trace is corrupt. What does it mean and what can i do to fix it?
Other strange problem that I encountered was that my program runs fine under the Debug mode for 55 minutes but as soon as i hook it up or program it...it craps out saying LOw on memory. What could be the possible reason behind that?
Ankur
Ankur
Can you post a file of your code ?
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
www.parallax.com
Posting a subset of your code that exhibits the problem is a great idea because it will allow someone else to verify the problem and see if it is because of the code or because of your hardware setup.
Chris.
I will post my code in a bit.
Ankur.
