Measuring amplitude
I want to monitor a DC signal and when its amplitude gets over X, then the STAMP will output a high signal to a pin. I will set X using a turn-pot. I am not too sure what approach to take concerning the amplitude measurement. Any ideas? Thanks in advance
TG
TG
Attached is a screen shot of data. The red trace is shock position from the linear pot. The area inside the yellow box is what I want to detect.
Post Edited (TG) : 6/9/2005 4:36:24 PM GMT
IF the pulses transitioned the 2.4V logic threshold (hope I got that level right) then you could use the count command or pulsin (being that it's about a 24Hz ringing).
http://cache.national.com/ds/LM/LM231.pdf this is a voltage to freq converter but they do have a sample circuit for a freq to voltage converter....of course you might need to amplify your ringing so that it crosses a certain voltage level!
Steve
http://ca.geocities.com/steve.brady@rogers.com/index.html
LM2907....and look at the Typical Applications section. If you have questions on its operation, write back.
K
Post Edited (KenM) : 6/9/2005 7:31:58 PM GMT
