railgun bore inspection robot
I'm new to robotics (I've never built one from scratch).·
Well, the robot I need to build needs to fit into a 38 x 38mm bore, but then also stay centered in a 76 x 38mm bore.· The robot needs a camera (I think I've found one here: http://www.supercircuits.com/index.asp?PageAction=VIEWPROD&ProdID=4013), about 8 LEDs that should either be able to dim and brighten or just have a couple turn on and off.· Distance detection is also important, I've thought about sonar and the other option that's come up is a digital tape measure.··(Distance from the end of the bore, the·longest bore is 7 meters).· For centering I've thought about whiskers, but that would require steering and the people that I'm working with want to keep it so the robot only moves forward and back.· So, my lab partner wants to put wheels on the side that spring out, or something to that effect.· Currently, I'm in charge of buying motors and gears (I never was good at mechanical physics) since my lab partner's out of town for the week.· Basically, I'm just looking for ideas on how to possibly implement some of this and where to find parts that are small enough to fit into the bore.
Post Edited (soyyam) : 6/9/2005 5:18:58 PM GMT
http://www.smallparts.com/
At the scale you are talking about, using a laser distance measure will provide the highest accuracy.
They do make cameras this small. Now, motors: If there are servo motors this small, do they have enough power to be useful? Servo motors would be the easiest to interface with the BS2.
I wonder if a 'tethered' mode would be possible -- have a BS2 with some motors on a 'platform' with the camera, drag a 'tail' wire which would supply power, and return video signals to a 'parent' PC.
www.kronosrobotics.com
Built a 'rover' for inside heating ducts -- but it was much larger, I believe. Still some of his techniques might be helpful.
Post Edited (allanlane5) : 6/10/2005 4:24:11 PM GMT
http://www.allproducts.com/search/products/pM01030431.shtml
http://www.usahardware.com/inet/shop/item/40940/icn/20-031328/midwest_fastener/4086.htm
