SX-key simulator not starts.
Hi Folks,
I was very happy with the simulator
part of the Sx-key 3.10 SW. I tried out on my several
source code.
t was working fine.
The problem occured when I tried out my USART program.
First the simultator was ok. I put two break points
into the code, an run it. It happened that I had got
an endless loop at that time.·
· could only quit the
simulator by using windows program manager.
After this the simulator not starts at all.
What have I done.
1. I repaired the program using install file.
Result: The problem remained.
2. Uninstall the Sw.
3. Switched off the computer.
4. Inatall SX-key again.
Result: The problem still remains.
What can I do? Should I check the registry or what? Can anyone help me?
I have attached the error message which I have got when I tried to close the Sxsim in the windows manager.
Regards
Spiller
source code.
t was working fine.The problem occured when I tried out my USART program.
· could only quit thesimulator by using windows program manager.
What have I done.
Regards
Spiller
could you please post the source code causing that error or send it as eMail (g.daubach@mda-burscheid.de)
Greetings from Germany,
G
when I looked at the image with the error message you had posted, I noticed Hungarian text in the bigger window. I do not really understand the Hungarian language but I know how it looks like as since 1987, I have visited your country quite often (for vacations, and for business). On these trips, I - at least - learned enough of your language to survive, i.e. I can order a beer (egy s
