STAMP 2 Serial Confusion
I have the Basic Stamp 2 Carrier board. I want to do real-time communication but have seen some references to the effect that this is not possible on this board. Why is that so? Is there anything I can do (cutting traces, installing a switch, etc) to allow both programming and real-time?
I really just need to receive on the Stamp, but send/receive would be a bonus.
Finally, (separate question) What would be required to be able to run the debugger WHILE I perform real-time communication? Is there a way to connect a second PC port via one of the parallel inputs? What would be required for that?
Thanks very much,
Keith
Thanks very much,
Keith
Jon Williams
Thank-you for your prompt reply. One remaining question. If I don't mind sharing the one port alternately for programming and real-time, are there any limitations with the Stamp 2 Carrier board for Real-time? Seems like I caught some reference to issues with using the carrier board for real-time....
Thanks again,
Keith
Jon Williams
Post Edited (Jon Williams (Parallax)) : 6/9/2005 2:01:25 PM GMT
Thank-you. The Max-232 looks like a perfect fit. Can you recommend a site where I can order this part in small quantities (1 or 2)? Most of the sites I found are more interested in thousand quantities.
Tahnks,
Keith
·· Try Digi-Key or Jameco.· I have purchased from both.
csavage@parallax.com
