DOA Stamp, any hope?
I just recieved the two boebots that I ordered from Ebay. One has a stamp that won't boot (No Stamp Detected). I've swapped stamps and carrier boards between the two and am convinced it is in fact the stamp that is bad. Also I measured some voltages on the pins and am not seeing +5 on the reset pin. Is there any hope for this stamp to ever come back to life? Any white wire trick or 4 leaf clover or anything? I realize these units were sold "As Is" but kind of thought that the statement that all the pins were tested meant that the stamp itself would work. I'm bit disappointed
Don Leuenberger
Don Leuenberger
Please contact tech support at 1-888-997-8267 and ask for Dave Andreae.·
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
www.parallax.com
Don Leuenberger
Sout = -5v
Sin = -10v
Res = +5v
Vdd = +5v
The voltages here should be referenced to Vss.· The two stamps that you received·DOA that you mentioned, are you able to program other stamps in the same board and PC?
Dave
Dave Andreae
Tech Support
www.parallax.com
All voltages are within range less one
sout = 3.7 v
sin = - 10 v
rst = + 5 v
vdd = + 5
Dave
Dave Andreae
Tech Support
[noparse][[/noparse]url]Http://www.parallax.com[noparse][[/noparse]/url]
Don Leuenberger
