Soldering
I am building a circuit board and am looking to buy a small soldering gun. I have soldered things before, but I have never soldered on circuit boards or small electronic components. Does anybody have and soldering guns they would recommend or any advice on how to pick one out? One of the things I will be soldering is a BS2, do you have to be very careful on the amout of heat you use and how many watts your soldering gun is? Also, what type of solder to use?
Brian
Brian
For small projects a 25-40 watt iron should be fine.· Use solid 60/40 solder (if you can get it, in some cases you will be forced to buy lead-free) -- if your board is clean, flux will not be necessary (and just creates a mess to clean up).
Jon Williams
Brian
One of the contradictory things of life is that people begining in electronics use cheap soldering irons. These irons make it more difficult to solder, but they are cheap. I run into this problem in the basic electronics class I teach. I can't afford to buy good irons for the students, so they have to suffer with the cheap ones. If they are having difficulty with a particular joint, I let them use mine.
I have a Weller WES51 that I have been very happy with. It has heat control in degrees ( not just 1-10) and an auto shut off feature, very good for the spacey like myself. You can get a wide variety of tips for it, which is very nice. It also can sense when you are using it and ramps up the heat, keeping the tip at a constant temp. when in use.
There are a lot of soldering stations out there, and you certainly don't need to go really expensive to get a good iron. However, I wouldn't reccomend going too cheap.
I totally agree with Jon about a socket for your BS2. However, I disagree about flux. I use flux on every joint, every time. Of course, I also use a lot of salvage and surplus parts, which may not be perfectly clean. I just wash the·flux off· with alcohol and a toothbrush.
HTH,
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
Sid Weaver
Need a bezel for your LCD?
Newzed@aol.com
Post Edited (Newzed) : 6/8/2005 5:05:08 PM GMT
Sid Weaver
Newzed@aol.com
Spend a little more on your iron...I can't tell you how frustrating it was for me when I had a cheap iron...and how different life became when I got a more expensive one....
Ryan
They are not as good as the expensive wellers, but decent. I would also get the smallest tip you can for it.
They are adjustable but the temperature is NOT regulated.
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"If you keep doing what you always did, you'll keep getting what you always got."
On the low end of the scale, there is the Xytronic 253 for $20, it has the features (mainly lack thereof) that RS irons have, but made with quality materials.
The Jali JF90ESD is also a pencil iron with temperature control for $50 (I don't think it is worth this price considering some of the following irons).
The Xytronic 379 is a soldering station with temperature control for $50 (good value).
Howard Electronics sells slightly used irons here, the Xytronic 136ESD is a better quality iron than the 379 for practically the same price ($55), The Xytronic 137ESD is the model I use. Several people from the forums have bought one of the used Xytronic 137ESD from them and I heard no complaints from them.
Sparkfun sells the 60W Sunco stations for $65 for the analog version and $100 for the digital version, goto Tools, page 2.
Bean's suggestion of the Weller WLC100 is a good middle of the road choice if you find yourself wanting a station (rather than a pencil iron) with temperature control and nothing else. (It's temperature setting is in watts, which I find annoying since you don't know what temperature corresponds to (plus wattage temperature control doesn't use temperature feedback resulting in wider variation of tip temperature under various operating conditions), and there is no electrostatic protection, but you would probably find both of these to be unimportant issues.
Post Edited (Paul Baker) : 6/8/2005 10:05:47 PM GMT
I find from my experience I like a small pointed tip.· If you are soldering something like the OEM board there is not a lot of room around the transistors so the small pointed tip is easier to work with without heating up adjacent parts.· Also regardless of the type of iron I have found that keeping the tip clean and tinned helps enormously with the heat transfer.·
Mel
I've seen ads for it in places, but the 2nd volume of Make Magazine had a coupon for it. You get it free immediately (not mail in) if you buy $20 of electronics equipment from Radio Shack. So, seeing as I need to pick up a few things at RS anyhow, I was wondering what this iron could be used for.
I'm a little concerned that there is a 'spark' when using the soldering iron. Could this cause damage to my SX kit or my SX52 proto boards? Still, it seems it would be handy for soldering speaker wires, tinning leads, etc.
Has anyone used one of these?
I am a HUGE proponent of butane soldering irons.· They heat up just as quickly as the most expensive electric and they're cordless!· I've been using a Weller Portasol (it was $60 from small parts; I don't know if it's still available from them) for 4 years now and I've only had to replace the tip once.· I use a very small pointed tip and a slightly larger (but still small) chisel tip.· One of the nice things about the portasol is that in addition to using soldering tips, it comes with a heat gun tip (great for heat shrink) and a hot knife (good for cutting through project boxes), plus the blowtorch tip that just about every butane iron comes with.· The gas output (and thus the temperature) is adjustable, but not self-regulating.· It'll go about 45 minutes if you have it turned up to full power before you have to refill it.· Butane is cheap ($3 for a can that will last you for about 20 refills).· Basically, for me, being cordless is priceless...
While it doesn't come as a station I find it perfect for surface mount and small circuitboard assembly. For heavier use, I still find occasional need for a 35 watt Radio Shack iron. I don't need it very often.
Google Antex to find suppliers.
