Sht11 - 1139,471
Hi All,
seeing some strange behaviour with my SHT11 temp/hum sensor.
All connections are solid. Code works great.
problem: Intermittenly the sensor returns a temperature of 1139 deg F, and a humidity of 471%. This only seems to happen once the ambient temp is over 90 degrees F.
any ideas whatsoever?????
from sensor reading values, I suggest you calculate by hand expected
temperature results for sensor reading values that are supposed
to calculate around 90 degrees F (take 87-93). There may be a discontinuity in
your formula regarding some reading values.
regards peter
