Getting the power out of USB
I am working on a project that will connect to a PC using a FTDI USB/Serial port.
The board uses 5V to work so I was thinking on using the power that comes out the USB port.
Is there any ready made FTDI board that provides +5V on the output connector ?
I got·a FTDI mini-board·but the +5V pin is not connected. Of course it·would be·possible to·reach the power pin using an extra·wire.
By the way, is·there an FTDI chip in DIP package· ?··
·· Also bear in mind that there is a limit to how much power you can safely draw from the USB port.
csavage@parallax.com
I was thinking to·use about 160mA. I thought I had available all USB·current (500mA)·but did not count on the FTDI itself! It is too bad. My·project looses a lot of interest if I have to·provide it with·a separate power supply.
I can't believe that they have an IC negotiating with the USB bus.
Not for $4.99 retail.
Bright white LEDs take more that 10ma.
Jack
Steve
