Inputs going thru LEDs on the way to a '165
I have a group of 4 to 8 push buttons providing input to a '165.· I want to have an LED light next to each button when the button is pressed.· Since the 165 doesn't seem to sink enough current to light the LED (it gets more current from the pull-up resistor to give it a dim glow), is there any other way to make these indicator LED light?
·· How about using double-pole push-buttons...When you press them, the second circuit can turn on the LED.· If you need the LED to stay on, you could use a 74HC595 on the same data/clock lines as the '165.
csavage@parallax.com
Thanks!
·· This thread is started to sound eerily like another one for modding a DDR pad to light up.· Anyway, yes, you can use the inverter to do what you want.· You can drive multiple device inputs in the manner you describe without issue.
Just to get back to basics for a moment, what is the point or purpose for having the lights?
Is the LED supposed to be ON and stay ON when the switch is turned ON or is the light just momentary and so too the button?
Bruce Bates
Free schematic drawing software at www.expresspcb.com
Easy to make a drawing and post in these forums.
K
Thanks!
Note that you would use the Qh output with the inputs being active-high.
Jon Williams
Post Edited (Jon Williams (Parallax)) : 6/9/2005 11:39:10 AM GMT
