bs1 timer
does anyone know how i could use this timer module to count down 1 minute for the setup cycle in one of my halloween props i want the stamp controller to know when the timer is up and when to set the timer again for the set up time.
Post Edited (JPrice5503) : 6/4/2005 1:36:38 AM GMT
·· Without any information on the timer, specifically model number and connections, we wouldn't be able to even guess how to interface to it.· Please provide more details on the timer.· Include it's operating voltage too please.
csavage@parallax.com
Main Power: 120VAC / 60Hz
Inputs: Count, Preset, Reset
Input level: 24 Volts or 120Volts, AC or DC
Digits: Uses 7-segment configuration
Std Color: High Efficiency Red
LED Life: 100,000 Hours typical
Enclosure: Industrial NEMA-12, 16ga. steel
Configuration: Available in 4-Digit configuration only
Relay Output: Yes, activated after attaining Preset, or Reset (jumper selected)
if you dont think that this timer will work then please tell me where i can get another timer that will work with the bs1
That said, why do you want to use an external timer when you can code one in your program? Or do you actually need the display that the timer provides?
Jon Williams
thanks
SYMBOL Trigger = PIN7
Main:
· IF Trigger = 1 THEN Main
Jon Williams
