Silent Alarm
Beau Schwabe
There are three major sections to this alarm...
The first section contains the Keypad which is a RadioShack Digital Controller Catalog # 49-535
I have made a slight modification to the ARM/Ready LED's to work with a single wire.
This section provides outputs for ARM and Ready modes as well as a Panic mode.
The second section makes decisions based on what happens to the zone inputs and the keypad section.
If the link to the keypad is broken, then a fault condition sets the alarm off.
When the alarm is set, the current condition of the zone switches are recorded.
If there is a change in zone switches, the alarm will be triggered.
The third section monitors the alarm status and will "Chirp" on some status changes.
The alarm will sound within a 5 second "timeout" if the link between the TX and RX sections are disrupted.
Note: A broken link requires a hard reset to the RX unit, otherwise if everything in the link checks out ok,
the Alarm can be disabled from the keypad.
Have fun!!
Beau Schwabe
Parallax IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 6/4/2005 12:54:23 AM GMT
Have fun!!
Beau Schwabe
