Programmable elliptic filter
Im curious how fast the the SX can be run using a peltier junction, heat sink and fan. To do this I'll need a programmable clock source, after searching high and low for a programmable oscillator with a·wide frequency range and high top frequency, I think that Analog Devices AD9581·is the best choice (5V, 0-180Mhz). The output is a DAC sinewave·and the package also contains an analog comparator to create a square wave (exactly what I want). The specifications state a low pass filter is placed between the output of the DAC and the comparator to filter out aliased versions of the signal thereby reducing jitter in the square wave. Thier example shows a 7th order elliptic filter whose corner frequency is 70MHz, I will need the filter's corner frequency to be adjustable (at least in the 100-150MHz range). While I studied the basics of analog filter design in college I have no experience and am having a difficult time finding a filter fitting these criteria that doesn't employ an expensive DSP solution to the problem. Can anyone guide me in the right direction, or think of a means of accomplishing the reduction of aliased frequencies without using traditional filters?
I hope this isn't a "cricket chirping" question.
As an aside, is there any problem driving the oscillator pin of the SX running at 5V with a 3.3V signal?
Post Edited (Paul Baker) : 6/2/2005 6:43:55 PM GMT
While what you're proposing sounds, err, interesting, I think you're missing the point in a few ways.
1) A sine wave clock to the SX is likely to be fine, if it meets the voltage thresholds and slew rate erequirements
2) How much jitter is there on the square wave output? Is it actually enough to be fretting about, in this application?
3) Since you don't care much about phase or amplitude performance in the filter (since its output is going straight into a comparator), it can be very, very crude. A simple non-tuned LC (or RC) will do - all you're trying to do is remove the quantisation noise. If you're using this to test the topspeed of an SX, I'd imagine that you'll care most about frequencies between 90 and 130MHz. Build a crude RC filter with a 3db point at, say, 150MHz, and I suspect it'll do all you need. (DSP-based filters aren't the answer in any way, shape or form, for this. The cost will be ferocious, and an ADC -> DSP -> DAC capable of filtering 150MHz, would _still) need a recnstruction filter on its output, so you'll have achieved nothing (except funding TI for a year...)
However, teh SX-key gets my vote [noparse]:)[/noparse]
Steve
Steve
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95 http://www.parallax.com/detail.asp?product_id=30012
"It's not getting what you want, it's wanting what you've got."
(Also, the original poster might want to go for something cheap & cheerful (and designd for the job) - a video clock synthesiser.
ICST ( http://www.icst.com/ )make some very usable candidates. Serially controlled (I2C or some other, according to the device you choose), low jitter, and easy to drive (or, at least, as easy as anything clocking at hundreds of MHz is...)
ICS1523 would seem to be a reasonable candidate. My old favourite, that I used to use for faking up clocks, seems to be obsolete [noparse]:([/noparse]
Steve
Sid Weaver
Need a bezel for your LCD?
Newzed@aol.com
The ICS8402 is good out to 350MHz...
(A little PCB with a SX, LCD and PLL chip, with a few buttons / serial port to set the frequency would be a very handy project, if anyone's bored...)
Steve
Thanks to everyone for thier input.
