Serial Help
I am having some trouble trying to use the SERIN and SEROUT commands properly. I am attempting to write program to act as a go between from the CMUcamGUI program on my computer and the CMUcam1 mounted on my boe bot. I've written a test program to see what the java based CMUcamGUI is outputting. My code is as follows:
SERIN 16, 84, [noparse][[/noparse]STR result\4] 'here I am using an stringarray with 4 bytes because the java prog is sending "rs/r"
FREQOUT 4, 2000, 3000 'since both the CMUcamGUI and my Stamp Editor Debug window use COM1
PAUSE 10000 'I've added these 3 lines of code to give me time to close the java app after it sends the "rs/r"
FREQOUT 4, 2000, 3000 'command and open the debug window to view what it caught.
DEBUG STR result 'this should output the string "rs/r" SHOULD is the key word here, heh
when I run the program as I described in the 'comments, all I get back is a weird character that looks kinda like a y with umlots over it (you know, the two dots you sometimes see over U and A and other characters in other languages. Any help here would be much appreciated. Been trying to puzzle this out for a while so I can get this program working with the bot/cam.
And when you're using the programming port (pin 16), you need to invert the data (a constant for that is built into the template too).
Jon Williams
·· There are no string variables on the BASIC Stamp.· You would need to use an array and deal with the characters one at a time.
csavage@parallax.com
' {$STAMP BS2}
' {$PBASIC 2.5}
counter VAR Byte
result VAR Byte
dataResult VAR Byte(4)
counter = 0
dataResult = 0
DO
SERIN 16, 16468, 10000, NODATA, [noparse][[/noparse]result]
dataResult(counter) = result
counter = counter + 1
LOOP
NODATA:
FOR counter = counter TO 0
DEBUG CRSRXY, counter, 0, dataResult(counter) , CR
NEXT
RETURN
catch VAR Byte
DO
SERIN 16, 16468, [noparse][[/noparse]catch] 'catching incoming byte sent from PC
SEROUT 7, 84, [noparse][[/noparse]catch] 'Send caught byte to AppMod CMUcam1
SERIN 9, 84, [noparse][[/noparse]catch] 'catch AppMod CMUcam1's response
SEROUT 16, 16468, [noparse][[/noparse]catch] 'send AppMod CMUcam1's response to PC Serial Port
LOOP
Any help will be greatly appreciated. Thanks!!
