need help programing stamp
Hello,
Last year I bought a bs 1, and used it without any problems. my computer died, and I bought a new one. I downloaded the parallax program, and wrote a new program. Now when I try to download a program to the stamp I get the error, can't open port, or no stamp found. I am using a·USB port.
Any ideas are welcome.
Thanks Frank Snyder
snyderfj@netins.net
Thanks Frank Snyder
snyderfj@netins.net
Jon Williams
On a technical note, the BS1 has always been programmed serially (at 4800 baud). The DOS version of the editor bit-banged 4800 baud serial for the BS1. Why use the parallel port? Because it has TTL level I/O and that made it easy to connect to the BS1 (no level shifter required). The BS1 Serial Adapater is simply a level shifter that takes serial port levels (which can be all over the place) and cleans them up to the TTL level required by the BS1.
Jon Williams
Thanks Frank
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
www.parallax.com
Frank
Dave
Dave Andreae
Tech Support
www.parallax.com
I was using the wrong com port. I think with a little work I will be able to download to the stamp. when I first changed the com port , it found the stamp, but wouldn't download. I got echo, but no loopback. I disconnected the power supply, and connected a 9 volt battery, and lost everything. I connected the power supply again, and still nothing. I will check out my wiring and try it again.
Thanks Frank
Frank
I don't mind the FTDI device, but if other devices work it is good to know about it.
